Ok here is the question, If you look at the intake of a turbo(35/40... . whatever) there is the outside ring(where the hose connects) then the inside ring at the inlet, if you cut slits between the two so you actually change the intake area will this benefit these small turbos, Yes I have seen this done on a 91mm last year, it was said that it fools the turbo into thinking it is bigger than it is, the guy that had this ran in NMRA ford series and was D/Q ed for it, Just wondering.
Jim
Jim
