HEMI®Dart
I was going to gasket match the exhaust manifold outlet to the turbo exhaust housing inlet ports.
Look at the pictures below.
See the 2 recessed areas just above the flange where the turbo bolts to the exhaust manifold? (right side picture better)
Inside the housing are 4 raised bosses (2 per side) on the bottom & top corners of the ports. The opposite of what we see on the outside.
It looks like if I can grind these down (the raised bosses on the inside of the housing) I could really be able to make this thing flow. I`m guessing at minimum 10% better flow. Probably more. These raised bosses are pretty good sized. Maybe an 1/8" tall or better.
Are these cast into the housing to make it more rigid?
And do you think I`d break thru
if I ground & polished the bosses flush with the ports? I looks VERY possible.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 12-16-2000). ]
Bill R
