I have been noticing over the past few weeks my turbo whistle (no silencer ring)
Has had a strange ticking or churping
sound above 20 psi and when it does it I only get 25psi boost. When it sounds normal the boost goes to 29psi. I took the air inlet off today, since it was making the noise almost every time it spooled up, and found that I was able to move the blade shaft up and down and side to side in the housing:--) Not Good I know for something turnig that fast. Is there any such thing as replacing the bearings in the turbo or should I find a replacement?
Anyone have a good used HX35W cheap??
