Schwitzer S300G #174430
57MM Extended tip Compressor Wheel
65MM 11 Blade HTB Turbine Wheel
. 80 or 12/14 cm2, Housing
This is the info I have on the S300G, which is the same as the Super B except for BDs wastegate. I've talked to lots of guys running these turbos and they love them. They say it spools very quickly and makes great power.
I'm not crazy about my HTT 62/12, wish it spooled faster, though it is faster than stock. It is supposedly a larger and tougher turbo. I ran two stock WH1C turbos at over 400 hp for a while. I think the best one can do is sequential turbos like your stock turbo with an HT3B.
You really should be fine keeping your stock turbo under 400 hp unless you tow very heavy at high altitude for extended runs. Otherwise, I don't think you'd have any problems. I would do as any would suggest any start with at least a pyrometer and boost gauge, and try modifying your plate first.
If you have no need for the stock plate, start by grinding it yourself and sliding it forward, as well as the AFC. Adjust your boost to allow up to 35 psi, maybe just plug off the wastegate. Then add your injectors and you'll know if you need a bigger turbo by watching your gauges. Knowing how hot it gets under what situations will help you select the right turbo.
If I were you and really wanted reliable power potential, I'd go with bigger injectors, grind my own plate, advance the engine timing, keep the stock turbo, but add a bigger turbo to flow and cool your top end. Not too big a second turbo or it won't spool without really big injectors like stage 4s. I like my stage 3 injectors. More than enough fuel. My current setup surges horribly at times and doesn't control EGTs so making the right match is important.
