The turbo housing on my '93 has what looks like 18B0 cast into its housing, and I see no wastegate. I'm guessing it is the stock '93 18. 5cm2 housing, and that the previous owner (PO) simply slapped a coat of paint on the compressor housing and slapped some Banks stickers on the fenders (haven't measured the pipes yet, but besides a boost and pyro gage, I'm not sure what else is Banks). I'm kinda bummed that this isn't the 14cm2 wastegated housing... but that looks easy enough to change.
FWIW, this turbo does not spool all that fast, but stays well within safety limits, touching highs of 19psi and about 600 degrees (post-turbo) during extended top-speed pulls up to just over 80mph, with no trailer.
I have yet to start fiddling with the injection pump -- I'm making darn sure I understand the function and inter-relationships between each adjustment before I do...
I'm midway through a search-n-research quest on opinions between 'gated and non-'gated 14cm2 housings. I've already seen quite a bit of talk about 12cm2 housings, but I don't think I want to go quite that far... . MAYBE I'd feel OK with that if it has a wastegate, otherwise it just makes sense that it would be choking on itself at Western freeway speeds.
If anyone has comments on what they think would be appropriate for 30% around-town miles, 60% unloaded freeway miles, and 10% loaded (6000lb trailer, mostly-flatland) freeway miles ... I'm all ears. I bought this CTD expecting longevity, and I'm will to increase the maintenance and even lose a bit of longevity in the name of performance, but (famous last words) I don't want to go too far down that path... once I add a tachometer, I'll be more willing to adjust toward faster fueling and higher EGTs.
Randii (hammering the SEARCH feature)
