Turbo Housing
Dodge Dealership stole my power!
Ok...370's on the way how hard are they to install ?
Am considering a larger turbo housing. I have 125,000 miles mostly towing. Should I opt for a complete housing/turbo combo or try to just replace with a larger turbo housing.
1996-3500 4x4 extended cab tst #5 plate, K&N air filter,Primeloc fuel filter kit,4" exhaust,Purodyne bypass oil fiter system, bigger injectors (215),b&m trans pan,Amsoil all around,temp gauges out the wazzo, much transmission work including TST upgrade kit and Bill Kondalays TC, Transfer Flow 98 gal bed tank,double tow 33' 5th wheel and 12' trailer w/motorcycle(Honda Valkyarie Interstate)Also have 1999-250-stock.
Installing governor spring kit(BD)on dualie.
The 16 cm2 housing and low restriction 3" exhaust will save 150-200 deg. If you need more egt reduction, you should look at the HX40.
TST also claims an aditional 20hp & 50ft. lbs. with the 16cm2 (when using one of their plates)
97' 2500, 2x2, 5spd. tst#10,afc springkit,silencer ring & kitty missing, straight pipe
