Not sure if this will help but the information is cool. This is from an RV forum.
Summary: ISB Engines
Solution:
Thanks for your Email message.
To answer your question on the ISB and Dodge venture. The Dodge Ram engine started as an 6B5. 9 with 12 valves. The current version is an ISB engine and is a fully electronic, 24 valve in-line 6-cylinder turbocharged B series diesel engine. It is an engine that is revolutionary thanks to something Cummins calls the Interact System. It produces a class leading 325 hp with 600 lb-ft torque.
We started building this engine over 20 years ago. It started out as a B5. 9 and in 1997 we put electronic fuel system on it. After that it is called an ISB engine.
The Cummins 6B5. 9 is the kind of engine that could make a big difference in your business, due to the engines excellent performance, durability, reliability and fuel economy. The Cummins 6B5. 9 engine is designed smart and built tough to produce the kind of power many applications demand.
The 6B5. 9 engine's performance is being noticed all over the world and the engine is produced in nine production locations around the world. The success of the Cummins 6B5. 9 engines is directly tied to its outstanding performance, which outperforms other competitive engines in its class, in many different applications.
The big advantage of the Cummins 6B5. 9 is its size and weight, which allows you to adapt the engine to about any application required. Through smart design, the Cummins 6B5. 9 engine is strong where strength is critical, since unnecessary weight has been eliminated. Also, the 6B5. 9 has 40% less parts, than other engines in its class.
Having fewer parts than competitive engines adds to the 6B5. 9's durability and reliability because there is less to go wrong and with fewer parts there are less things to fix. Also, the engine requires no special tools for maintenance repairs, since standard everyday metric tools are all it takes to get make repairs to the engine.
Cummins has built the standard 6B5. 9 engine series in various horsepower and torque ratings for many different customers for many years. The standard mechanical, 12 valve 6B5. 9 automotive engines from Cummins are:
160 hp with 400 lb-ft torque
175 hp with 420 lb-ft torque
175 hp with 430 lb-ft torque
180 hp with 420 lb-ft torque
190 hp with 475 lb-ft torque
210 hp with 485 lb-ft torque
210 hp with 520 lb-ft torque
215 hp with 440 lb-ft torque
230 hp with 605 lb-ft torque
There are also many other ratings that range from 100 to 325 horsepower for the Dodge Ram and off-highway applications, such as construction, genset, industrial, marine, mining, etc.
6B5. 9 - 160 vital statistics:
Horsepower 160 @ 2500
Peak torque 400 lb-ft @ 1600 rpm
Governed speed 2500 rpm
Engine cylinders in-line six
Bore & Stroke 4. 02 x 4. 72 in
Displacement 5. 9 liters (359 cu in)
Compression ratio 17. 5:1
Operating cycles 4
Oil system capacity 17. 3 quarts
Cooling system capacity 10. 5 "
Net engine weight (Std accessories) 942 lbs.
The automotive 6B5. 9 engine dimensions are:
Length 40. 02 in.
Width 32. 44 in.
Height 35. 52 in.
Weight 942 lbs.
The marine versions of this engine dimensions are:
(6BTA5. 9-M1) (6BTA5. 9-M2) (6BTA5. 9-M3)
Length 40. 69 in. 40. 48 40. 48
Width 30. 25 in. 32. 14 31. 40
Height 33. 94 in. 31. 73 31. 73
Weight 1,035 lbs. 1,175 1,225
In January 1997 Cummins announced the ISB 275 for RV use, which is rated at 275 hp with 660 lb-ft torque. The engine was coupled to an Allison automatic and has been used in many 1997 diesel powered rear pusher motorhomes. The engine was just released for the Dodge Ram pickup truck, however, rated at slightly higher hp and but less torque to accommodate the Dodge drivetrain. While the current B5. 9 and C8. 3 engines are certainly proven products, we are not aware of other applications such as Freightliner that may be switching to the more powerful ISB, however, we expect that they will. You might discuss this with Freightliner to find out if they plan to change their product line.
The Cummins ISB is a fully electronic, 24 valve in-line 6-cylinder turbocharged B series diesel engine. It is an engine that is revolutionary thanks to something Cummins calls the Interact System. The Interact System is a new engine design platform that combines sophisticated electronic engine controls with high-pressure fuel injection and high-strength componentry for engines that outperform every competitive diesel on the market today. The Interact System 'talks' to vehicle systems like the fan clutch and engine brake, as well as the power train.
The ISB engine is expected to deliver 15% more miles/hours to overhaul, with double the service interval of the current B series models. The engine also has increased torque and horsepower ratings and is up to 4 dB quieter than any previous B series engines. The fuel/water separator filter is designed for 15,000 mile service intervals and has a water-in-fuel sensor. The rocker system of the ISB is designed for minimum 150,000 miles without adjustment and the valve springs are standard 60 psi heavy-duty for use with exhaust brakes. The standard oil capacity of the Cummins ISB engine is 15 U. S. quarts and oil change intervals are recommended every 15,000 miles.
Fuel economy for the ISB engine has been improved 2% - 4% over last year's B5. 9 engines. The engines also have more response over the entire power range. The engine has an integrated air heater that automatically 'kicks-in' whenever engine and ambient temperatures drop, plus the ISB has a start-up protection feature that limits rpm until oil temperature and pressure are high enough. The ISB engine ratings include the previous B5. 9 ratings, plus new ratings at 230 hp with 660 lb/ft torque, 250 hp with 660 lb/ft torque and a special rating at 275 hp with 660 lb/ft for RV's, fire apparatus and school bus applications.
ISB ratings:
ISB175 175 hp @ 2500 rpm 184 hp @ 2300 rpm 420 lb-ft @ 1600 rpm
ISB190 190 " @ 2600 " 195 " @ 2400 " 520 " @ 1400 "
ISB195 195 " @ 2500 " 205 " @ 2300 " 520 " @ 1600 "
ISB210 210 " @ 2600 " 215 " @ 2400 " 520 " @ 2400 "
ISB215 215 " @ 2500 " 225 " @ 2300 " 520 " @ 1600 "
ISB215 215 " @ 2500 " 225 " @ 2300 " 605 " @ 1600 "
ISB230 230 " @ 2500 " 242 " @ 2300 " 605 " @ 1600 "
ISB230 230 " @ 2500 " 242 " @ 2300 " 660 " @ 1600 "
ISB250 250 " @ 2500 " 263 " @ 2300 " 660 " @ 1600 "
* ISB275 275 " @ 2500 " 275 " @ 2500 " 660 " @ 1600 "
* ISB300 300 " @ 2600 " 300 " @ 2600 " 660 " @ 1600 "
** ISB325 325 " @ 2900 " 325 " @ 2600 " 600 " @ 1600 "
* Restricted rating for RV/Fire/School Bus
** 2004. 5 Dodge Ram Heavy Duty Pickup
Details on the Cummins ISB engine:
Displacement 359 cu. in. (5. 9 liters)
Length 40. 03 in
Width 30. 32 in
Height 31. 72 in
Bore 102mm (4. 02 c. i. )
Stroke 120mm (4. 72 c. i. )
Compression ratio 16. 5:1
Dry weight 437kg (962 lb)
Oil Capacity 14. 2 liters (15 US quarts)
Fuel filter Top load cartridge - Fleetguard FS 1261
Spin on filter - FS 19519
Oil filter - Fleetguard - LF3729
Oil Drain Interval - 15,000 miles or one year (whichever comes first)
Recommended oils - 15w40 API CE/SG
Valve adjustment - 150,000 miles
The B-50 expected 'life to overhaul' time for the ISB engine is longer than the previous mechanical B series engines. Cummins expects the B50 life of the electronic 24-valve ISB engine to be in the 400,000 mile range or higher.
We thank you for your interest in Cummins products. Please let us know if you need assistance in locating the nearest Cummins-authorized Dealer or Distributor Service Provider. For assistance in locating a Service Provider, feel free to use Cummins North America Dealer Locator, which can be found on Cummins website:
http://www.cummins.com/service_locator/index.cfm
Please let us know if you have other questions and if away from your computer or have a time-critical request that needs more urgent attention, feel free to call us toll-free (from North America) at 1-800-DIESELS (343-7357). Customers may also call Cummins switchboard 1-812-377-5000 (worldwide toll call) and ask for the 800-DIESELS Call Center for assistance.
Email direct: -- email address removed --
Regards,
Powermaster
Customer Assistance Center
Cummins, Inc.
Columbus, Indiana, USA
