Engine/Transmission (1998.5 - 2002) Turbo Impeller Shaft
Engine/Transmission (1998.5 - 2002) NV4500 Pilot Bearing
Engine/Transmission (1998.5 - 2002) ebay 275 injectors
I WAS CLEANING MY AIR FILTER TODAY AND REACHED DOWN TO TO CHECK MY TURBO IMPELLER AND NOTICED A LITTLE PLAY BETWEEN SHAFT AND BUSHING. IS THIER SUPPOSED TO BE SOME PLAY. IT IS NOT SLOPPY BY NO MEANS.
Originally posted by Bob4x4
Yes some play is normal,radial clearance-. 0128-. 0195end play should be. 0015-. 0035 in
Bob
[/QUOTE
When the oil pressure hits these bearings that play will disappear.
cheers, Kevin
