Turbo Install Torque Specs
shutdown temps
2001 Ram Recall
I’ve decided that I want to remove my turbo before drilling my exhaust manifold for an EGT thermocouple. After all, if I can’t perform that simple task, I’m truly at the mercy of my local DC dealer for all service, and that is an ugly thought.
I’ve already purchased all of the gaskets, under $2 total at the local Cummins shop #ad
. I’ve got all of the tools. I have the gauge and thermocouple.
What I don’t have is all of the torque specs for re-installing the turbo. If one of you fine gentleman (or ladies) have a shop manual and could provide them, I’d greatly appreciate it. As best as I can determine, I need the torque specs. for the following fasteners: Turbo (to Exhaust Manifold) Mounting Nuts, Oil Return Mounting Bolts, Oil Supply Line Nut, and the Exhaust Flange Bolts (Exhaust Pipe to Turbo Elbow).
Thanks again
2001. 5 Intense Blue 2500 QC, SLT, 5. 9L 24v Cummins, 4x2 Auto, 3. 54/LSD, 155 inch WB, Agate, Trailer Tow Group, Sliding Rear Window, Line-X over the rail, Leer Cab Height Topper.
[This message has been edited by RamBoat (edited 04-26-2001). ]
According to my 1998 service manual from Chrylser, the following torgues are listed:
Turbo to exhaust: 24 ft lbs or 32 N. m
oil supply line to turbocharger bolts:18 ft lbs or 24 N. m
Oil supply line nut: 133 INCH lbs or 20 N. m
Exhaust bolts: 25 ft lbs or 34 N. m
Air inlet pipe nuts: 72 INCH lbs or 8 N. m
Hope this helps. Good luck.
EK2_T/A:
That's just what the doctor ordered.
Thanks
