Turbo installation
need to let her breath some more
48RE Thrust Washer
kblranch
I plan on installing my new/used Bomberlite and need to know what the torque specs are for the turbo to exhaust manifold bolts, turbo to inter cooler hose clamp and the oil return tube bolts. I also need the torque for the air intake horn.
24nm/18ft lbs on the intake horn.
24nm/18ft lbs on the oil return line.
43nm on the turbo to manifold nuts.
Intercooler clamps are touchy, I usually run them down to match the others or go tighten until the clamps ends are about and index fingers width apart.
