Someone Help !! I have a 1997 ram 3500 5. 9 cummins , I started having starting problems when it got colder than 40 degrees, im in the midwest . i had resorted to using starting fluid more times than i should have, i virtually left the truck pluigged in 24 /7 when the truck was not going to be driven that day or even days at a time . truck ran excellent when it was going down the road. i parked it at the the end of the fall season and stopped driving it for the summer. it sat for 4 months . i went to start it and it would crank and not fire up , i misss diagnosised it and put lift pump in , still no start, found out the fuel shut of solinoid was the problem , install it it started hard but got her running, 15 min of idle time it smoked alot and i shut it down and oil was dripping out tail pipe , I figured i blew seals out of turbo , removed and yes hot side was leaking , ordered hx40 after market on ebay installed , 10 minutes of run time it was blowing oil out cold side and hot side of turbo , returned turbo , ordered a second turbo from a another manufactuer, 15 min of run time , same thing !!! checked oil return to block from turbo perfect , what could be problem ?
