Engine/Transmission (1994 - 1998) Turbo issues
2nd Gen Non-Engine/Transmission Abs speed sensor, axle swap
2nd Gen Non-Engine/Transmission front 3.55 to 4.10 ring pinion swap
Hope this is the right Forum for this question I have a 96 Cummings with a Banks Turbo system. Recently, the turbo "dump" has opened up while driving and I loose power. I banged on the waste gate actuator and it works fine now. Should I replace the waste gate actuator? Thanks in advance.
Len and again thanks
I would remove the actuator and check the wastegate can pivot freely.
Thanks so much for the quick reply. I will give that a try today, if it ever warms up here. I live in So. Ca. in the hills above LA, and the temp this AM is 19 degrees.
There are some good videos on YouTube that explain the operation, function & correct procedures for adjusting.
Staying with stock boost range is recommended without further engine mods.
Thanks very much. Yes, I watched several videos related to the Dodge and it was very good. Again many thanks.
Len
