I was wondering if anyone has run into a situation where a rushing or exhaust resonance noise is heard from within the cab coming from the general direction of the turbo when either the throttle is abruptly backed off or when the shifts to a higher gear, particularly when shifting to overdrive while under load? If I had to guess at something it sounds like boost air bleeding off in someway that is creating this strange noise. Could there be a torn hose(s) that I should be looking for?
Thanks!
Don
Thanks!
Don
