Would I be better off?......
Depends on how much the HX35 is, what housing is on it, and what YOUR future BOMB plans are. If you plan to remain at or near stock (airfilter, exhaust, pump tweaks, no injectors), and the price is less than half a new PDRHX35-14/16, then I'd sya go for it. Be sure to get a boost elbow for the wastegate if it isnt off a 215hp engine. You'll want 20-25psi boost minimum from the 12cm housing, and stock 160-180s are set for around 15-18psi, or so I've been told.
If you plan to eventually go all out (not that I know anyone of that leaning), then I'd save up for a PDR HX35 or a HX35/40 hybrid (HX35 body and exhaust turbine/ housing; HX40 impellar wheel and housing- allows you to keep stock exhaust and get airflow of an HX40, or that's my understanding of it. )
If it is a HY35 of a 24v auto, I'd pass on it unless you plan to stay bone stock and have 3. 54s with an auto.
Daniel
