I thought that I would resurrect this thread since I finally got around to installing the drain pipe hose. First of all, the hose, p/n 5086952AA was rather expensive. It listed for $44. 46 and I paid 29. 95. The hose is silicone I’m sure. I also bought a gasket for the drain pipe where it connects to the turbo. The p/n for this is 5003332AC and it listed for $3. 85 and cost me $1. 27. I get the reduced price because one of the parts guys is a friend.
You have to remove the air filter housing tube and the oil filter to gain access to the drain pipe hose connection. The hose is about 4 inches long. On my truck, the drain pipe is in two pieces. The longer piece extends from the turbo – it joins a shorter piece, via the hose connection, which is pressed into the block. The space between the two pipes is about 2 inches or so. I had to cut the old hose off both pieces of pipe in order to remove it. You have to remove the pipe at the turbo or pull the pressed piece out of the block in order to put the new hose on. I chose to remove the piece at the turbo and that’s why I bought the gasket. It was a bit hard removing the old gasket material from both the pipe and the turbo connection. Since I did not remove the turbo itself, I had to use a mirror to see underneath where the pipe connected since I was looking straight down.
I used a 10mm wrench to remove the two bolts at the turbo connection. The gasket comes with one side a bit sticky. I pressed that side to the flange on the pipe but it still tried to come off. The two bolts would not stay in the holes even through the gasket. So be careful that you don’t drop one somewhere you can’t find it. I finally managed to get the two bolts into the turbo connection. I used a ¼” drive socket and ratchet to snug them down.
