turbo oil supply line
Leave the engine running
Dodge/Cummins backcountry reliability
My turbo oil supply line has started a slow leak at the connection to the top of the turbo. It's leaking at the flare connection that goes into the little adapter.
Does anyone know the part #'s for the supply line and adapter or have a suggestion on where to get one made up?
Sean
I would think you could get the fitting at most any hydralic supply store and probably at some well stocked hardware stores. I would try that first before I invested in a line. After that, I would hit up Cummins. I don't have my parts catalogs here or I'd try to get ya a part #.
Carl
Sean,
Carl's correct... . you should be able to buy a replacement locally..... there is a local "fluid power" store near me that stocks all that kind of stuff... . Drive the truck, bring one of the counter guys outside to look at it... he should know exactly what to make up for you.
Good luck.
Jay
