Engine/Transmission (1994 - 1998) Turbo opinions
Engine/Transmission (1994 - 1998) delievery valves?
2nd Gen Non-Engine/Transmission AC driving me nuts!
Ok finally got the required money to purchase a turbo... so with my mods assuming that im going to put newera edm 370s and a set of 191dvs minimal light towing, main thing is a daily driver, and wants to kill stock mustangs and fart-canned ricers on the weekends@the strip also need to find the best possible price on them and where to get them.
TIA Casey
Casey...
Southern MD you could call either one of the shops below...
Lloyd Mills(TDR Member-lmills)...
His shop is located in Hagerstown,MD and he is a High Tech Turbo Dealer. I add a link to his website for you. . (240-818-2973)
Home
OR... .
Call Brett and Chris(TDR Member-c-hawk)...
They own TNT Diesel Performance out in Ridgely,MD. They deal with most turbo companies and could also fix you up. I will also add a link for you to them..... (410 310-9171)
TNT Diesel Performance - MD
Hope that helps some... ... Andy
I'd do a 62mm S300 variant.
and I wouldn't do the 191's, especially for towing
Agreed,
I have run several chargers and the sps62 is the best daily driver imo, spools up quickly and comes in early. Bigger chargers are better in competition, no doubt, but a 62 is a lot of fun in a driver ;)
Dave
After trying several turbo's from several sourses, I finally got a 62/14 from DDP in Monroe Wa.
I cannot say how much I like it. I tow a 38 foot toy hauler with a gross of about 21,000lbs and it makes towing a pleasure.
Plus I do like to show off now and then. Like out pulling a friends twin turbo powerstroke while towing a empty race car trailer (5,000lbs) and him with no trailer, and never going over 1,250 degrees.
And just to add salt to an open wound, I get 5mpg better than he does.
now im worried sounds like i shoulda went with a 64 or 66 i bought my turbo first then the injectors(stupid)oh well im used to pyro being pegged lol, it only goes to 1500. so who knows how hot im really gonna be maybe i can slide my plate back?
TIA Casey
well i installed my turbo and although im very happy with it my pyro still gets pegged with these pensacola 90hp 4x. 014 hole injectors, and stupid me ordered DDP4s, what was i thinking do you think i should try to send them back and get DDP3s or say screw it w/ the 4s and just slide my plate back? can a htt62/71/14 handle higher egts over a stock turbo? all i want to do is drag race and cannot afford water meth or any other mods for a while thanks in advance Casey
I'd bet the ddp4's run the same or less egt than those 4x14's, there bigger sure, but ddp makes a nice injector, my ddp4's are cleaner and cooler than 370's. I'd try 'em, there is a return spring on the throttle, remember? :-laf
Dave
I'm no expert by far, but I'm going to say you'll do alright with that turbo. I went with a II PS62/65/12 and put in DDP4's. I was a little worried at first, but after install I'm glad I got the 4's. EGT's a little hot on wot (1350). I went with the smaller turbo for use as a twin set-up later.
How do you like it so far. I've heard good things about a 62/71/with 12,13s/s, and 14. How's the spool-up?
lol, well with all my fuel it wont clean up the 4s as i expected but its not as bad as i thought it would be , about the same as my old injectors but twice the power, (its a lil scary)lol but spool ups not bad.
Casey
