Turbo Orifice???
Stupid Question W or D?
1st Gen essential traveling tool kit
Unless you are running a waste-gated turbo exhaust housing. This would have no place to mount or be of use to a 1st gen truck. Our stock exhaust housings are not waste-gated.
It is used on the 94 up to what year I do not know. It has a restrictor built into it to slow down the waste-gate opening to allow the turbo to build more boost.
All it is, is a standard fitting with a ". 060" hole drilled in it. You can do it yourself for free if you have a drill bit.
