The air inlet to my 12cm turbo is 4" in diameter, the outlet is 3" in diameter and looks like it does not use a slip-on hose and hose clamps. The inlet and outlet of the intercooler are 2-1/2" in diameter, and the inlet to the manifold is 3-1/8" in diameter. What am I supposed to do?????
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo, thermostaticly controlled twin 14" electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, R-134, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
