Ob1kobi is right
A small amount of play is normal cause the shaft gets so hot, it needs room for expansion. If the shaft or bearing was too loose you'd probably experience an oil leak. Check the manifold for loose bolts,cracks,or the turbo exhaust inlet for leaks or looseness before you condem the turbo. Merv
