A friend and me were talking about turbos and he said the inside dimensions were the same no matter if your turbo was a 12 -14-or16 cm, with a 4" outlet. Therefor a down pipe larger than a 3" was of no use since the inside of the turbo was a set size. My question is, is that so?If that is true I can see where he would be right.
Also on another subject does anyone know anything about the Excide battery that is of the same makeup as the Optima. The battery is sold at NAPA. 84 mo. warranty with 100 CCA. $100 each.
Thanks
Preston
Thanks
Preston
