ec-120, ec-130
Since we are so far off track here is a little more. Find someone in your area who is running them and have a good sitdown. Try and find someone with a few hours on an airframe not a new aircraft. on both aircraft the doors suck. they are easly broken and the fit and finish sucks. the wind screens and windows are structural. no popout vents allowed. the air con cannot be mel'ed. if it goes out it's grounded. The windscreens often debond and need to be changed, which is a 3 day job. The tail boom is lined with tin foil(no $#!7) on the inside and is a monocome setup(one solid piece) any dent or scrape is non reparible. You change the whole tailboom. The battery is placed over the tailboom/ airframe junction point. Not a good place to have corrosive battery acid. Eurocopter will not allow you to split the engines. if you have a single problem with the compressor, gearbox, or turbine you pull the whole engine. On a 206 you can split a allison 250 series engine in the field and change any section. I could go on and on, there are many, many other items I could point out. The bottom line is make sure you get the whole picture first before you buy. Eurocopter pulls alot of people in with a low cost product, but they keep a tight reign on the parts supplies. There are no aftermarket or outside suppliers. They do not allow it. sometimes parts have to come from france and that can meen two weeks of non rev time. I quit I am going on and on. I quit. copterdoc
