What's up guys, first post here... Long time lurker but now finally forked down the $$...
Question - anyone running a HX35 or WH1C or similar turbo in their 4BT? Is the wastegate used or needed, does it/should it choke out in the 4BT if the wastegate is disabled? Did anyone have issues with the wastegate actuator hitting the block?
I am trying to tune this 4BT for optimum power for towing and getting over the mountain passes here in Utah (8000 ft) in 5th gear but as little smoke as possible and best mileage. I just bought a complete WH1C which is basically a way they souped up the H1C for a quick year before they went to the HX35... They used these in 94 Dodge only, I found good info about it here: http://www.dodgeram.org/tech/dsl/FAQ/turbo_faq.htm This one that I bought is actually really low mileage and all seals seem to be in great shape so I would really like to use it. But... the wastegate actuator hits the block, so I can't install it. My original H1C now has a blown seal on both inside and hot and it saw about 10 hours of very hot EGT's because of a blown headgasket that started to manifest itself on a road trip and I would prefer to put it to death anyway... So I have a few choices:
1) Weld wastegate shut and remove actuator mechanism on WHIC. This sounds hoaky to me and I was thinking I wouldn't do it but the more I think about it the more I think it might not be a bad idea... Because, if for some reason I have too much boost (which I doubt I will), I can always grind the weld off...
2) Switch to a non wastegated housing. A local turbo company will trade me straight across, a brand new OEM Holset 12cm2 non waste gated housing in exhange for my wastegated housing. The end result is basically the same as option 1 above except I'd have to buy a 14 cm or back to my 16 cm housing if it was choking out or other negative factor...
3) Move wastegate actuator somehow, sweep it forward? But I havn't found a single kit or anyone who sells some sort of way to move it. Plus the actuators are expensive, so this will probably not be a cheap option... ?
I actually typed this yesterday for the yahoo 4BT list so, a little update, I went with option number 2 today. I figure it should be fine but I was talking with a PDR guy when I bought my Bosch 190's and he said the 12 cm2 might be too much especially if I am looking for highway power so initially I decided against it. Now I have this, the 12 cm housing and now the larger impeller of the WH1C so I think I should actually be seeing some pretty larger boost numbers, 20-25PSI easily?
Just wondering if this is too much or if I'll be choking it at all now that there is no wastegate. I know the turbo can handle it as can the engine but I am trying to tune for mileage and highway as mentioned before. But of course I won't mind the in town power either though
Thanks guys. .
Andre
Thanks guys. .
Andre
