On my truck i have an HE351 turbo. i believe its a 60/60/9 no i am not quite sure what this means. can some one please explain?
Also with a turbo if say you increase you wheel from a 54 mm to a 60 mm does this mean you will increase you turbo lag or just air pressure?
What is the difference between a 6 blade compressor wheel and an 8 blade compressor wheel?
Is the HE351 a ball bering turbo or does it contain bushings?
