Turbo questions
Shaking/vibration at idle
Dana 70 shudder
I just got a new turbo to go onto my truck. I am trying to figure out what size exhaust housing is on it. This is a new housing. It does not have the markings on it like the orginal one on my 93. The casting number is 35619-410 on the exhaust housing. There are a couple of other numbers on it to. just below the casting number is a 129. There is another number right beside it. It is a two degitt number. I can make out a 1 but the second number I can't make out.
I am hoping someone knows what size it might be. If it is a 18 cm I'll just throw it on and not worry about breaking my old one apart. This is a H1c model turbo also.
I could find any info over on holset website.
It's most likely a 18. 5cm. I just dove into my engine box to check the numbers on mine :D On the outlet side it has HOLSET 18. 5 CM and below that is 3519-410 there are some numbers on the other side of the casting, but I can't see them too well. When you take your old turbo off the truck, just put the exhaust housing next to the new one and compare the size. If it's a 21cm you'll be able to tell because the inlet passages will be taller and fatter, not by much, but enough that you can see the difference.
Cheers,
Sean
GREAT, THANKS SEAN!:rolleyes:
The one time I thought I could answer YOUR question, and he beat me to it. I just went out and looked at mine, and I confirm the casting numbers on the factory housing off the 93 turbo. Also, didn't that one have the 89-91. 5 hose end on the compressor side? If so, you'll get to take it apart anyway...
Jim
Good glad to here it is a 18cm housing then.
Its raining here so I am not going out to look at the inlet side to see if it is the same. :D
