I think Deleting the DPF & EGR is the fix. LOL
I KNOW my turbo is clean and happy now !
Cheers,
Yukon Chris
Anyone know if they are going to recall the 07. 5 turbos for the turbo charger variable vane seizing up?#@$%! Any news on the TSB for cleaning these things with the Millers special tools parts 10142, 10143:{
Regards Conn
Ya, just take a piece of fuel line or tube that will fit into the hose that goes to the turbo. Remove the hose where it goes into the intake and you can get a 1/2 in pvc pipe plug, the threaded ones, and it should fit right in where the hose came out. Make sure to plug that hole or you will be drawing in unfiltered air. Then run the new hose into the vent tube and down along the wheel well. Find a nice spot to stow it and away you go. Mine has not dripped at all since I vented it out. This is one of the easy mods you will have on your new truck. Keeps the whole intake nice and clean.
Cheers,
Yukon Chris
any good suggestions on the deletions?![]()
Regards Conn
