Turbo shutdown timer ?
Service in DFW
thermocouple leads
Curiouser and Curiouser.....
Anybody familar with the Isspro Turbo Timer? Seems like a good way to let me make a stop without me being on the seat and waiting for the EGT's to drop.
Colin
:confused:
Additional
Works' as indicated. I installed following Steve's schematic with major modifications. I installed the second relay in the PDC. Mounted the TSM box under the dash on top of the climate control box. Very clean installation. :cool:
The only drawback is that you cannot set the factory alarm while the engine is running. :eek:
I ordered one from DIS last week. Should be here in a few days. I'm gonna hook it up using Steve St. Laurent's schematic. Sounds simple: pull the key, lock the door, and walk away!
Steve
Purchased the one from Geno's. At 86K miles still not a problem.
The installstion is an electrical plug in plus drilling two holes, one for the activation button, and one for the security switch. Worth the money for easy install! Getting ready to order one for Moms Ram. :D:D:D
Clarification
Originally posted by C. D. Day
Purchased the one from Geno's. At 86K miles still not problem.
The installstion is an electrical plug in plus drilling two holes, one for the activation button, and one for the security switch. Worth the money for easy install! :D :D :D
Your refering to the TurboDiesel Lifesaver, the Isspro set up they are refering too actually uses a pyro to shut off at a specified temp. So there are two different products here.
Just don't want people getting them confused, I jsut bought the Lifesaver from Geno's but haven't installed it yet. Looks rather simple tho.
Kat --- You'll like the lifesaver. I understand there is a difference in type of operation.
If you see Mark Davis walking thru the halls up in Omaha, tell him I said hello!
