I've got a code, P0236 Turbo / Super Boost Sensor A CKT Range Perf, swapped map sensor from another truck, no change truck is in limp mode and the scanner can't clear the code. I'm running one of those boost replacement sensors on the wire that used to go to the stock turbo, so I pulled the old unit from my stock turbo and still the same thing. Anyone got any ideas. I've already unhooked the TST and the SP module.
