Engine/Transmission (1994 - 1998) Turbo Swap
Engine/Transmission (1994 - 1998) turn up boost?
Engine/Transmission (1998.5 - 2002) ATF+4 - why so hard to find?
If the 98 24v has the wastegate plumbed into the compressor housing you can just plug the line on the 12v, other than that it should be a straight swap.
Thanks,
It looks to be pretty simple, but if I did that swap, the 12v exhaust housing would be used on the 24v turbo, would there be any kind of problem with two wastegates :confused:
Steven
