BTighe said:ill call it sold and well let tdr name the price based on averages. the first 5 prices posted. well avereage them out. ?
Greenleaf said:The exhaust housing is longer. It will not bolt up unless you do something about the down pipe OR remove the 12cm gated housing from the HX-35 and install a non gated exhaust housing. Then stuff will bolt on.
Be aware that if the first gen turbo doesn't have the oil feed adapter bushing, you'll need one.
The OEM size for the 97 compressor wheel "should" be 56mm. The OEM size for the first gen "should" be either 50 or 54 depending upon the year.
-S
JLEONARD said:Personally I think $200 for a turbo with 175K on it is too much. $100 to "maybe" $150 tops.
But that's me.....
Jay
bgilbert said:That's what I was thinking, $100 tops for that high of mileage. I'm cheap though, so I'd only give $50.
-S
