wow, are you gonna get lots of answers on this.
1. turbos have lag when you floor it, blowers dont.
2. turbos only use waste gas pressure to run, blowers always require mechanical drive power even at idle.
3. blower compressed air tends to be a little cooler than turbo compressed air, however both increase air temp with pressure.
4. blowers do not require cool down time - turbos do.
5. a blower is considerably larger than a turbo, based on equal amounts of volume and pressure.
6. blowers become disproportionately expensive as their boost pressure capablities goes up. most don't go beyond 15 lbs.
6a. turbos go to 40 lbs or better in one stage.
7. i have never seen a wastegate on a blower. blower speed must be closely matched to engine displacement and desired max boost.
8. finally and most important:
turbos have a cool sound - blowers just make noise.
jim
