I have a pdr hx35 with 14cm wastegated housing.
My issue is that at low boost, useally at decelerate, I experience a warble in the turbo whistle or whoosh. . whoosh... whoosh... . whoosh... ..... whoosh... ... ... ..... whoosh... ... ... ... ..... whoosh... ... ... ... ... ... ... ... ... whoosh... ... ... ... ... ... ... ... ... ... ... ... ... . whoosh. It will do the same at low boost or cruise speeds. During aceleration it will do the same but it reverse order. Kinda like it winds up then winds down.
I thought it may be the new pdr hx35 but after I installed the stock back on it it did the same thing so I dont believe its the turbo.
My thoughts are exhaust leak but I can't find any signs of leaks.
Maybe Intercooler leak or hoses. All are tight and look good but I dont know how to do a pressure test.
Maybe its the new EGT probe that I installed. It isnt exactly center in the rear exhaust its kinda to one side but not touching, maybe it flutters or does some kinda whirling vortex in there.
Everything else seems ok and it runs fine, I can get as much boost as I want from it and it doesnt do it when I give it some good pedal or higher boost just around cruise or low boost of 1-5 lbs.
Maybe its just the way it is.
Odd thing is that it didnt start to do it until about 200 miles after I installed the new pdr hx35. Then it didnt seem to get more apparent after that.
I talked to Piers and he said he had never heard that situation before at low boosts but maybe at higher and it doesnt do it at higher boosts.
I was going to return the PDR hx35 but since the original does it too I need to look elsewhere or nowhere. AAArrrrggg!
Any thoughts or answers would be greatly appreciated.
Thanks
Thanks
