i like loud turbo whistle! will the afe drop in filter give the same result as a K&N as far a letting more whistle be heard? what have you guys found. my ring has already been xed and that helped but i want more. I plan on ram airing my box with a tube straight out to the front and aslo i am going to cut (2") into my firewall run back to stock box like the scotty.
unrelated if you want miter cut tip in four or five inch just like stock to replace from the bent to the tip in chrome i found the place. instead of buying those cheesy clamp on tips you will have to cut 18" off of the end of stock exhaust and weld on new 4/5 18" chorme tip(it will look like oem tip but it will be chrome. $56 dollars plus approx. $35 for somone to cut and weld on new piece. www.berubes.com
