Can someone provide a comparison to each of the following:
S300
S400
S500
Pls use well known turbos for comparisons. Tks
S300
S400
S500
OT-OF-HERE!! said:I recently taked with ATS and they are putting together compounds using the turbos I sought info on. I needed to get an idea of what levels these turbos were at to see if they matched my needs. That info you provided was a help,... tks.
jwilliams3 said:Phat shaft (and super and SB) And HTT 62, 64, 66 = S300
High Tech Turbo HTB2 and 71 Series= S300
TAD B1's=S300
TAD B2=S400 (75mm inducer @ compressor) OEM part number 171702
Alot of good info on S300 from Borg Warner:
http://www.bullseyepower.com/s300bigsheet.htm
Here is an excellent page for info on Borg Warner Turbos:
http://www.centralturbos.com/pop-werks7a.htm
zstroken said:LOL true true, but I can think of a pull where the veteran only put about 2 feet on me and I think at scheid the following day he only put 2 or 3 also. The key is consistency and I don't have it with my truck. One day it runs good, the next time, it doesn't. I was suffering from PCM problems at gaston, hence the accidental shifting to drive followed by the abrupt down shift to second and about 4000 rpm.
zstroken said:On a 12V???
