Originally posted by JJW-ND
On the newer trucks pulling the buzzer causes problems with other stuff. It works fine on 1997 and older trucks.
Like Eric said, get a small skinny torx screw driver to reach the three small screws on the bottom side of the sterring housing. The that forms two halves with the ignition on one side.
With the screws out, the two halves will seperate with a little persuation. You should find a small connector the plugs in just below or under the the ignitition. Unplug this (you can plug it back if you want the DING back).
This will get rid of the ding with the key in and the ding when door opens.
The dinger the warms you when your lights are left on STILL WORKS, and the dinger for low fuel STILL WORKS.
jjw
ND
