My experience with turning rotors is "dont't turn them"!!!. Every time I have had rotors turned they whorped within 10,000 miles. I had a couple of old trucks that had real bad grooves cut into the rotors, but the rotors were not whorped. they worked fine for many, many miles and years. I turned rotors before to get the groves out that previous owners put there (even though they were not whorped) and sure enough within 10K they were shot. If its not pulling and it stops good. don't turn them.
good luck
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
1975 Toyota Landcruiser, ARB Air lockers Front & rear, 400 Small Block, SM420 4spd, Stock LC transfer case with 2 or 4 high and 2 or 4 wheel drive Low gears, 15. 5x36" Radial swamper on 12" rims, Custom front & rear bumpers, Roll Cage, Warn 8274 8000# winch, 2. 5" spring lift, 2" body lift. Premier on-board power welder, on-board air, 4-wheel power disk breaks, power steering, Lot of fun.
