I just had a new aluminum flatbed built and installed on my 2001. 5. Thinking they are way cool (literally) and extra bright and warranted for 10 years, I opted for all lights to be LED. I didn't anticipate a problem that I now have. The LED's draw such low current that the electronics on the truck are sensing that I don't have a full load (i. e. : a burned out lamp) and flash the turn signals at the high rate to indicate a burned out bulb. I contacted Grote, the manufacturer, and they indicated they were aware of the problem and it has only been showing up on late model light trucks, the 2000 and 2001 Rams at least but they have no solution at the present time. No problem on semi applications, etc. Guessing that the circuit needed a bigger load, I spent about $5 on parts and made a load that plugs into the trailer plug. Viola, problem solved. Now to the question. Anybody know how this circuit works? Is there an after market flasher that would cure the problem? I tried 3 automotive supply houses here plus the local dealer. Never heard of this problem and no answers. My $5 solution appears to work, but would like a more professional and permanent fix, other than something plugged into my trailer plug. Any thoughts and help appreciated.
Shelby
2001 2500 QC LB 4WD, ETH, DEE, 3. 54 gears, Laramie SLT, Camper Special, Trailer Tow, Travel Convenience Group, Power Driver Seat, Alarm System, Remote Keyless Entry, Fog Lamps, Cab Clearance Lamps, HD Transfer Case, Bright White with a Gray Interior. Took delivery on 10-06-00. Coming soon: E-Brake and a custom aluminum work body / flat bed.
Shelby
