2nd Gen Non-Engine/Transmission Turn signal/marker lamp bulb
Engine/Transmission (1998.5 - 2002) Codes??
Just quick question. How is the best way to go about replacing a front turn signal/marking lamp. I looked this afternoon and took a couple screws out but the corner lamp wont come out. Doesnt look like it can be reached from under hood either. Just want to be able to go out and change it quick... ... Its too cold to be an idiot. :eek:
Use a sawzall...
*LOL*
Actually, you do it from outside the truck. There's a philips screw holding the light to the body, and once you take that out, pull the marker light assembly out. Simple. :D
When Evan says pull it out he means slide (pull) the light assembly forward. if you put a flat screw driver between the back of the light and the fender a slight pry will move it so that comes off of the clips in the front.
