Turn signals hate cold weather?
Star Wheel? Old School/Piers..any info?
Windshield wiper problems at freeway speeds?
My turn signal won't work now! If I'm lucky sometimes they'll blink once or even a few times if the truck is warmed up good. Anyone ever had this? I haven't. There's probably some "thingy" on the fuse block that needs replaced or just kicked and thrashed like I have to do for the heat fan to work. Any suggestions? I'm to lazy to try and figure it out(as I have do do that type of crap all day at work)
  • '93 250 LE 4x4 5spd 4:10 Loaded,dual 5" chrome stacks,12cm² turbo,PW injectors,K&N,pyro/boost,US Gear E-Brake,tool box,CB,10" AR rims, 285/75/16 Bf goodrich. "wirenut_21529" on Yahoo Messenger
  • '96 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
  • '94 GMC 2500 6. 5L Turbo
PICTURES.
Wirenut,
It sounds like your turn signal flasher went out. It's that round thingy above the #1 fuse in your fuse box. A good way to check this is to swap it out with the other round thingy on the R/H side. This is your Hazard flasher. After swapping it out, check your turn signals. If they operate normally and your hazard flashers are slow, you found your problem. About five bucks at most auto parts stores.
89 D-250 LE 5 speed 3. 55 Limited slip, K&N, straight piped, Boost/Pyro. & 16cm2 215K and still going. 91 W-250 5 speed, 4. 10 Limited slip, 16cm2, 6" Skyjacker lift, RS9000, Dump bed, 18K original mi.
Yeah, I kicked and slammed my fuse block around and they worked for a minute but the "thingy" still needs replaced. Thanks for the confirmation.
Good description DJP!! #ad
Wirenut, I tend to agree with DJP that the flasher has taken a dump. Another thing to check is to make sure all the light bulbs are working. The flashers need the resistance from the lamps to work properly. Most of the time if a light burns out the flasher goes into high speed. Just a thought on this.
Stan
93 2WD extended cab, Banks Power Pack, K&N Air Filter, PW Injectors,Auto w/4. 10 rear with limited slip, US Gear Exhaust Brake, 31/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, new 40-20-40 bucket seats, 149K
[This message has been edited by paccool (edited 11-21-2000). ]
