Turn signals on "the blink"
OD Idea?
dana 70
My turn signals quit working the other day. Checked the fuse, changed the flasher itself and still nothing. Bulbs are all good as the 4 ways still operate normally. What else in that circuit is prone to failure? Anyone else ever have this happen? Got to get her fixed soon, inspection time!
Chris
Chris,
I don't know, but are the turns and the 4ways on the same flasher? I had a problem with mine last summer and the flasher I had just replaced, kept jiggling loose. It's currently taped in place. That did it for me.
The turns and emergencies are on different circuits and different flashers. Swap to a known good flasher unit to verify it is not the flasher unit. If that doesn't work it may be an issue in the turn signal activator in the steering column.
I had the same thing happen to my 90 ramcharger. It turned out to be the turn sinal switch. You can plug a new one in at the base of the steering column to make sure that is the problem before you take it apart.
The turn signals and the 4 ways are on separate flashers and I have swapped in one that is good with no result. It's looking like the switch at this point. I see in the manual there is a procedure using an ohmmeter to test the "multifunction switch". Maybe I'll give that a whirl to see if anything is abnormal. Thanks for your input guys.
Chris
I have just the opposite problem- turn signals, but no flashers. Could they be related? The problems, I mean, not the flashers and turn signals :rolleyes:.
Daniel
