2nd Gen Non-Engine/Transmission turn signals
Engine/Transmission (1998.5 - 2002) In tank fuel pump
Engine/Transmission (1994 - 1998) 95 model 12 valve tps.
Better to get electronic flasher IMHO. The resistor adds load to the circuit to get flasher to work. Electronic one does not.
Absolutely correct. Originally I used resistors with my LED's, those suckers dissipate a lot of energy as heat defeating one of the benefits of LED; lower power consumption. The flasher is a good fix, your truck should take an EP27 flasher, find one designed for LED's, here is an example (not sure of quality of this brand) : http://www.oreillyauto.com/site/c/d...ck=Search_01546_1354799_-1&pt=01546&ppt=C0117
SHG
