Dont do the mack rack travel plug on a 215, its not needed. the 913 and 887 pumps suffer from the plug, to much rack.
Same with the gutted AFC. you will make more power with it set up CORRECTLY than gutting it. All gutting it does is make the tree huggers more apt to get what they want and ban all petro engines because of the smoke you will produce.
A 0 plate in the correct position, 4K's, timing, a CORRECTLY set up AFC, and a clutch that will hold it should make 360-380hp at the rear wheels. a 16 cm housing will help too. That same setup with some timing, 370's and a turbo will put you in the mid 400's.
For injectors, contact Don M, DDP, etc. 370s are not bad injectors either, for the price. They are really really hard to beat, the only draw back being some haze. The good ones arent to bad though.
And dont ever take your truck to a shop that says they will turn it up 10%. That right there means they have no idea what they are doing. And avoid shops that say "we will turn your pump up 2 clicks" like the plague... absolutley no knowledge there... haha.
Also, you can do the KDP yourself. its not bad if you get the Jig from Marv...
--Jeff
