the only thing you would do is lower egt and gain lag and only boost as much as the better performing turbo, unless you had a trick intake manifold to keep the systems apart. then you still wouldnt boost as high but the flow would be there, series twins multiply boost, at 80 psi, one turbo could be making 10psi and the other 30psi.
