the benefit of twins is that you reduce the pressure ratio each turbo is operating under... this keeps the charge temps (and resulting EGT's MUCH cooler)
as you compress air, it gets hot, the more it's pressurized, the hotter it gets...
when you ask a turbo to operate outside of its efficiency range, it starts heating up the air a lot...
if you have a single turbo (or even twins in parallel) making 60psi, you're asking it to pressurize the atmospheric air FOUR TIMES over atmospheric
now, if you ask a pair of twins in series (one blowing into another) to make 60psi, if they're sized right, you don't need them to pressurize as much... say your big turbo pressurizes the air to 20-30psi, and then the small turbo takes that pressurized air and pressurizes it to 50-60... each turbo is only has to pressurize a couple times over atmospheric, so it doesn't heat up the air nearly as much.
anyhow, twins in parallel are good for a gasser that makes high power at low pressure ratios if you can't afford one turbo that's big enough to move the necessary CFM... there's a BIG difference between making 800hp at 25psi and making 800hp at 100psi!!! the first will require one HUGE turbo or a pair that can support 400 each...
you also run into problems with making sure the compressor maps are right... I'm pretty good with maps on gassers, but I don't have enough experience (nor can I find detailed holset maps!) with the diesels to know how they react to different compressor maps... taking two stock turbos and running them in parallel is usually a recipie for disaster... the turbos aren't any more effective at high boost, they just tend to surge off boost and take forever to spool up. you'd generally go with two slightly smaller turbos that are more effective at higher pressures, BUT in this day and age, unless you're talking about rediculous HP numbers like 2,000+ a properly sized single is the way to go (on a gasser of course!!!) with the pressure ratios required to make these diesels really get, compound setups are THE way to go!!!
Forrest
