I guess in theory, you could remove your wastegate flapper and arm, and weld everything up so that you had two seperate paths... then bore the wastegate hole out as large as you can, and then plumb an external out of that hole. but it seems like it'd get kinda tight back there at the back of the motor. I'd rather run the external between the manifold and the top turbo.
Forrest
