If you were to have parallel vs compound turbos ...
you would have to run much smaller housings on the two turbos than you would a single. . 2 HX35s vs 1. . to get them to spool at the same rate, but now you have twice the mass to spin up. . a loosing proposition. You would still only be able to make the pressure that a single turbo would.
Gassers generally run twin turbo's to simplify the plumbing and allow them to use 2 smaller, cheaper turbos . They also run less than 20psi(way less) for the most part. Performance diesels usually run 40+psi of boost.
Because diesels use compression vs ignition to fire the fuel charge they are not harmed by the increase in pressure that is possible with compounds... and boost+fuel = power
Turbo boost pressure is not absolute. . not a fixed increase... but is expressed in terms of a factor of input pressure. Therefor if you take a small turbo that would normally be undersized for an apppliction (this means it will spool really fast) and feed it with a larger turbo you can build huge pressures without the need to exceed the map of the smaller turbo.
an HX35 easily attains 35 PSI of boost... ambient + (250% of ambient)
if ambient is changed from 14psi to 25psi you go from 35psi of boost to ~88psi of boost WITHOUT OVERSPEEDING THE TURBO!
I got distracted and you typed this while I was gone... .
I think my point is this. With a small turbo you get the benefit of quick spool up but are hurt on the top end with restricted air flow. By running two small turbos in parallel you would still have the quick spool up but by adding the 2nd turbo you would effectively double your flow or volume. Right?
you will still only make 40 or so psi of boost. . which means you can only stuff the same amount of air in the cylinder given the same temperature. the size of the cylinder is fixed so the power at 40psi is the same across the board... until temperature changes. Larger turbos make cooler boost for the most part so the air is denser an makes better power.
This is sorta hard to explain is so few words yet be accurate. there are some simplifications here.
Later,
Mark
