I would like to know the best way to remove the plug covering the second oil drain hole in a 2002 block. Also I was told that a bracket was needed to help hold up the bottom turbo. In the Pdr kit I see a piece of of 1/4" hrs flat with two holes drilled in it and another piece of 1/4 x 1 hrs with angles on the ends. Is that what is used for the bracket or do I need to fab up something.
Thank you.
RonA
Thank you.
RonA
