jwilliams3 said:
Doubt it.
Cooler the better for longevity.
Easier on the rings, block (coolant), gaskets etc.
IMO
I'd encourage you to re-think your doubt. WHY exactly are lower temps easier on the block and rings? Gaskets, I will grant you.
But the engine is designed to SUSTAIN EGTs up to 1300 or so indefinitely. That means that piston clearance, ring gaps, etc are all spec'd with this temp in mind.
In most engines, cylinder bore wear goes DOWN as cylinder operating temperatures come up. I don't remember where I saw the graph. The reason is that the piston's expansion in the bore produces a tighter fit, equalling more piston stability and LONGER ring life.
Bore/cylinder/piston life gets longer as the cylinder temps gets hotter, RIGHT up to the point of seizure. Ever notice how many racers report that an engine has run it's absolute best JUST before it blew up? (think Nascar or Midgets, or Sprints).
Same thing with oiling systems. Higher operating temps burn off moisture, which reduces the formation of acids. Oil flows better when it's hot, allowing better lubrication. (Yes, this also breaks down the oil faster if running dino).
Cooling systems operate at their given temps because of the limitations of a water-based coolant and the small range between operating temp and boiling temp. A higher temp (if possible) INCREASES engine efficiency, as it results in less heat loss to the coolant.
That's my argument, what's yours?
jmo
