Details here: TDR Privileges
I have a 98 that has 370's, 191 delivery valves, 64 mm compressor housing, and a 16 cm non w. g. turbine housing. would there be any advantage to putting a stock second on. if so what kind of gains.
Once you go twins you will never go back! I ran a PDR HX35/14gated with some EDM injectors for a long time. Then I did the PDR Towing twins. . execpt I used a 12cm gated housing on the 35 to spool things up lower. .
Now my truck drives like a sports car... Spools like right now.....
the larger bottom turbo is the collector turbop it will grab a bunch of air and then the upper turbo will recompress it before it passes through the intercooler giving you a much denser air charge and ... . a greater combustion :--)
