twins....
48RE behavior question
lock up
i am starting to install my custom twins. . i did all the fabrication and bell turbo did the turbo's i really hope this set up works. .
any advice on installing
dustin
plan a long weekend or a couple days off. When you are doing a custom set that does not come as a package deal, it is easy to forget the little things that will keep you from running the truck.
Other than that, HAVE FUN. :D
leaks suck! take your time fitting clamps and lining up pipes. re-check clamps after you drive it up to full temp once or twice. carb & choke cleaner works good on boots for grease removal and leaves the boot tacky so it wont blow off at 60psi ( that noise will leave skids in the drivers seat) . have fun.
-robert
